RMS Express SmartSDR Latency
Ron K2RAS
I have RMS Express loaded and communicating with my 6500 and SmartSDR using Winmor 2K. A dedicated CAT port is configured in Smart CAT. The radio is in DIGU mode with AGC off. Unfortunately no stations are responding to the radio. The T>R latency is indicating between 300 and 400 ms. Any idea from the experts what the problem might be? I have reviewed the posts in this community and the online help and believe that I have set everything up correctly.
Thanks, Ron
K2RAS
Thanks, Ron
K2RAS
Ron, a long latency period is normal for a SDR.
My WinMOR setup, which works with boxes in Europe follows.
I have set the session bandwidth to 1600 and left drive level at 100.
Radio settings:
Your CAT and PTT ports may vary.
The sound card tnc shows 372ms latency:
The 6500 is set to DIGU - 5.0K - FAST - DAX1.
This setup works, but I use PACTOR for EMCOMM with
a FT-897D or FT-857D, where latency is abt. 10 ms.
Alex DH2ID0 -
Ron,
I will confirm that this latency is normal for the DSP in the 6500.. RMS Express/WImor will tolerate up to 1000 msec latency but it does reduce the through put a somewhat... I would guess that the DSP latency in the 6500 might be able to be tuned for ARQ applications, but I would not hold my breath.
AL, K0VM
Thanks for the assistance,
I got the system up and working. My connection attempts to 80M/40M RMS Winmor sites seem unreliable, but that may be due to my limited Carolina Windom antenna. I am still getting a handle on how strong the signal must be relative to other digital modes such as RTTY and PSK31.
Connections to 20M RMS sites seem more reliable, but obviously very slow. I would hate to send long emails using HF Winmore, much less attachments.
Thanks again,
Ron
K2RAS0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
