Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
RMS Express SmartSDR Latency
I have RMS Express loaded and communicating with my 6500 and SmartSDR using Winmor 2K. A dedicated CAT port is configured in Smart CAT. The radio is in DIGU mode with AGC off. Unfortunately no stations are responding to the radio. The T>R latency is indicating between 300 and 400 ms. Any idea from the experts what the problem might be? I have reviewed the posts in this community and the online help and believe that I have set everything up correctly.
Thanks, Ron
K2RAS
Thanks, Ron
K2RAS
- 70 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 89 SmartSDR for Mac
- 144 SmartSDR for iOS
- 150 SmartSDR CAT
- 70 DAX
- 279 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 558 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 155 Power Genius Products
- 120 Power Genius XL Amplifier
- 12 Power Genius Utility
- 23 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 90 Remote Operation (SmartLink)
- 50 Contesting
- 131 Peripherals & Station Integration
- 63 Amateur Radio Interests
- 408 Third-Party Software
My WinMOR setup, which works with boxes in Europe follows.
I have set the session bandwidth to 1600 and left drive level at 100.
Radio settings:
Your CAT and PTT ports may vary.
The sound card tnc shows 372ms latency:
The 6500 is set to DIGU - 5.0K - FAST - DAX1.
This setup works, but I use PACTOR for EMCOMM with
a FT-897D or FT-857D, where latency is abt. 10 ms.
Alex DH2ID
I will confirm that this latency is normal for the DSP in the 6500.. RMS Express/WImor will tolerate up to 1000 msec latency but it does reduce the through put a somewhat... I would guess that the DSP latency in the 6500 might be able to be tuned for ARQ applications, but I would not hold my breath.
AL, K0VM
I got the system up and working. My connection attempts to 80M/40M RMS Winmor sites seem unreliable, but that may be due to my limited Carolina Windom antenna. I am still getting a handle on how strong the signal must be relative to other digital modes such as RTTY and PSK31.
Connections to 20M RMS sites seem more reliable, but obviously very slow. I would hate to send long emails using HF Winmore, much less attachments.
Thanks again,
Ron
K2RAS
