Why so problems reported about DAX error
Paul - The issue you are experiencing is not due to anything residual left over from uninstalling the SmartSDR ecosystem using the procedure posted on the HelpDesk (https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSD...)
This is driver "crud" leftover from the upgrade that can be next to impossible to remove (removing a driver in Windows doesn't actually remove it). Some of it may be registry keys that cannot be easily removed even with admin privileges.
In some cases like this, doing a Recovery Rest or reverting back to the previous operating systems, removing the SmartSDR ecosystem and then doing the upgrade are the only options that provide any remedy. http://windows.microsoft.com/en-us/windows-10/windows-10-recovery-options0 -
"Won't it be possible to program a small delay into CAT and DAX, to get them to start a wee bit later than FlexVSP?"
Yes. We have it as an enhancement request for an upcoming version of SmartSDR
Yipiiieeee! Great! Thanks, Tim!
Tim,
Window crashed hard this morning when going from 10 back to 7. So, I've opted to just replace the entire hard drive with a new SSD type and start over from the ground up.
It would be a good idea, I think, to add a warning in advance of any SSDR upgrade that any change in Windows O/S should first be accomplished with a clean SSDR removal (using your linked instructions). Then add it back in after the O/S upgrade. Probably this advice is already posted somewhere, but I sure missed it.
Anyway, I'll close out the support ticket.
Paul, W9AC
Nothing, I run Win7 and Win10 as VM on an Apple MacBookPro. I think a lot of people don't take the time read the book on how to set it up. This has probably been said quite a few times, the first thing that you have to do is select a DAX channel in the slice receiver you have open. The next thing is to select DAX in the transmit area of SSDR.
The other thing that I have done is to remove DAX from automatically starting when you start Windows. DAX is a client of the radio but if SSDR is not running I found sometimes it will give you fits. I always start DAX after SSDR is running. I've never had any problems using this scenario.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
