RMS Express SmartSDR Latency
Ron K2RAS
Ron K2RAS Member ✭✭
I have RMS Express loaded and communicating with my 6500 and SmartSDR using Winmor 2K.  A dedicated CAT port is configured in Smart CAT.  The radio is in DIGU mode with AGC off.  Unfortunately no stations are responding to the radio.  The T>R latency is indicating between 300 and 400 ms.  Any idea from the experts what the problem might be?  I have reviewed the posts in this community and the online help and believe that I have set everything up correctly.
Thanks, Ron
K2RAS
  • DH2ID
    DH2ID Member ✭✭✭
    edited March 2017
    Ron, a long latency period is normal for a SDR.
    My WinMOR setup, which works with boxes in Europe follows.
    I have set the session bandwidth to 1600 and left drive level at 100.
    Radio settings:
    Your CAT and PTT ports may vary.
    The sound card tnc shows 372ms latency:
    The 6500 is set to DIGU - 5.0K - FAST - DAX1.
    This setup works, but I use PACTOR for EMCOMM with
    a FT-897D or FT-857D, where latency is abt. 10 ms.
    Alex DH2ID
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    Ron,
       I will confirm that this latency is normal for the DSP in the 6500..  RMS Express/WImor will tolerate up to 1000 msec latency but it does reduce the through put a somewhat...   I would guess that the  DSP latency in the 6500 might be able to be tuned for ARQ applications, but I would not hold my breath.
    AL, K0VM
  • Ron K2RAS
    Ron K2RAS Member ✭✭
    edited June 2020
    Thanks for the assistance,
    I got the system up and working.  My connection attempts to 80M/40M RMS Winmor sites seem unreliable, but that may be due to my limited Carolina Windom antenna.  I am still getting a handle on how strong the signal must be relative to other digital modes such as RTTY and PSK31.
    Connections to 20M RMS sites seem more reliable, but obviously very slow.  I would hate to send long emails using HF Winmore, much less attachments.
    Thanks again,
    Ron
    K2RAS
