smartSDR has alzheimer's
DaveC
DaveC Member ✭✭
edited December 2018 in SmartSDR for Windows
version 1.5 seem to forget some of my setting when changing back and forth between bands. I have had the A.G.C turn back on, after I had turned it off, for a particular band after switching back and forth between bands. I also have had the DAX turn off. especially after a power cyclic. This use to work in the previous release.
Radio: Flex 6300
Comment on this user group: The search is pretty poor. When I do a search it always seems to give me over a 1,000 results. Almost useless.
  • DrTeeth
    DrTeeth Member ✭✭
    Re: the search facility. IIRC, it only searches the subject line and not the messages' contents. Never managed to use it successfully
  • Bill  /  VA3QB
    Bill / VA3QB Member ✭✭
    edited August 2017
    Instead of searching this forum, I do it in Google. Just put the topic item with flexradio as the first word.   Here is a good example  put this into Google search.  "flexradio RF Gain"
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited November 2016
    I believe I reported that about a year ago. I believe the upshot was it was in my head. Sometimes it seems to work, sometimes it doesn't. But switching band and having agc-t pop at 70 is deafening.
  • Richard G7EIX
    Richard G7EIX Member ✭✭
    edited October 2015
    You can use the site: option in google to search a specific site....
    For example:
    site:community.flexradio.com smartsdr settings save
    And one specific to you needs....
    https://www.google.com/search?q=site%3Acommunity.flexradio.com+smartsdr+settings+save&oq=site%3A...
  • DaveC
    DaveC Member ✭✭
    edited May 2018
    Just an update/observation:
    If I enter a frequency directly in the slice, the settings don't change.
  • Steve-N5AC
    Steve-N5AC Community Manager admin
    edited December 2016
    I agree with this sentiment.  I generally do a Google search and insert the search term: site:community.flexradio.com
  • rich
    rich Member
    edited March 2016
    Yes, I too think that it has been reported; but I've never seen a formal, workable resolution.
    This difficulty (forgetting settings after band switching) is still present in 1.5.1, albeit, happens very rarely.
    I've found that always having a "TX Profile" selected seems to reduce the problem.
    GL, 73, Rich, K3VAT
  • IW7DMH, Enzo
    IW7DMH, Enzo Member ✭✭
    You need to use the decimal point after the MHz cipher. For example 7.020100 and not 7020100.
    73' Enzo
    iw7dmh
  • DaveC
    DaveC Member ✭✭
    edited May 2018
    This has not been addressed by Flex. Is it going to be fixed, or is it a "feature"?
