CWX always transmits
Jim Shaffer
I am using Flexlib 1.4.16 with a Flex 6300. I expected CWX.Send to send only if .Breakin is true, but it always transmits. If I key down, using a key for example, and .Breakin is false, I don't actually transmit. I would expect CWX to work the same way.
Good observation Jim. I had never noticed, but as you say, it seems beneficial to be consistent with keyer behavior, I suppose one could make the argument that using it for code practice ... turn power to zero.
The Break In option only affects the physical Key input on the radio. CWX always transmits if directed to do so in CW mode.
There are other ways to temporarily disable Transmit if this is the goal like unchecking the TX on the Slice control so there isn't a Transmit Slice defined.
If there is a use case where this isn't sufficient, please give us the details so we can improve the design. Thanks for your input.0 -
I guess what I'm expecting is that it should work like the key works if I turn Breakin off (False). Changing this would pose a backward compatability problem though. How about adding something like a CWX.MonitorOnly property? This would go through the monitor but not transmit.0
For monitor only or practice mode, I would suggest just turning the RF Power down to 0 and send away.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
