SSDR V1.5.0 - No Panadapter Signals
Hunter - K3IE
Can't figure this one out on my own so I have decided to call in the smart guys.
Uninstalled SSDR V1.4.16 and then installed SSDR V1.5.0
Flex 6300 is receiving audio but no sigs in the panadapter. Performed a reset of the 6300 and problem persists. Thought problem might be unique to V1.5.0 so I tried to revert back to V1.4.16 but problem persists - no sigs in pandapter.
Using Win 7.
Problem something simple that I am just missing. Appreciate any suggestions.
Thank you - Hunter K3IE
Using Win 7.
Sounds like you haven't selected a receiver slice. Hit the "+" in the lower left corner.0
Thanks Jim. Actually, I do have an active slice open "A". Audio is being received but no signal in the panadapter.
Also, the S-meter is non-responsive
What happens if you add another slice?0
I can't remember and I don't have acces to my rig, but under the Display settings is there a way to turn the update rate to 0?0
Are you viewing the rig remotely on a different LAN?0
The signal sometimes is below the bottom of the screen.you,perhaps,have already done this but bring the mouse over the right hand side of the pan, mouse down and slide the window up.0
Using the same LAN. All was working well until I updated to V1.5.0
Here is a pic with (2) slices and I did move the mouse over the right hand side of the pan and slid the window up. Strange that I can't recover through reverting back to V1.4.16
When this problem gets resolved hope you will post what the problem is. Sure is strange that it appears one version "destroyed" an earlier version.
Jim, K6QE
Will do Jim - thanks for trying.
- Hunter.
Just doesn't make sense. Perhaps removing all power to the radio and instituting a hard reset and a new reload would help. I am just making stabs in the dark.
Jim
Update - reverted back to V1.4.16.
just tried another reset. After resetting the 6300, the panadapter still did not work. I then shut the radio off and disconnected the P/S and waited a minute. I reconnected the P/S and turned the 6300 back on - Voila - the panadapter is now working agiain.
I have no idea why this worked but thank goodness - I can now get back to chasing the TX3X without being blind. I just don't know how I worked all that DX split over the years without this panadapter
I think I will wait till they have a new update to V1.5.0 before trying that again.
Thanks to all - Hunter K3IE
In my opinion (which doesn't amount to much) I think it would be better to reload 1.5 so you can add to Flex's data of problems to the 6300. The more input they can get, the better it might be for all.
Jim
Good point Jim - will do.0
Hunter - If you can tune the slice, then the issue is most likely a third-party security program is blocking the VITA-49 data from the radio. If you have any of these programs loaded, disable them to test this theory.0
Just wanted to update the group that the problem is solved. Dudley suggested to me, as Tim also did above, that my 3rd Party Security Software could be the culprit. I turned my anti-virus/firewall off and V1.5.1 is working well. Note to self on this one.
Glad it was something simple.
Very much appreciate your help and your patience - Hunter K3IE
Thanks for the update! We are so lucky to have not only a great radio, but great support.
Jim, K6QE
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
