WNB not working on my power line noise
Mike Barrett
I'm running a 6300 connected to a mag loop. WNB is doing very little to power line noise on 20 meters that the NB in 1.4.16 was able to remove completely. I reread the Noise Mitigation section of the manual and adjusted my AGC-T per Lee's videos but still no luck. With the WNB setting all the way to the right I get a very slight decrease in the noise but nothing nearly as good as the the NB in 1.4.16. After watching the pretty dramatic videos that others have posted, I feel like I must be missing something. Any suggestions?
Thanks!
Thanks!
3
I noticed the same thing last night on 80 meters. 1.4.16 did a much better job. Should I go back? I went to open 1.4.16 and it showed the "UPDATE" tab that I did when I went to 1.5. If I do decide to go back, will that mess anything up in the radio to run the "UPDATE" to go back to 1.4.16?0
You shouldn't have an issue rolling back. When you click "Update" in 1.4.16 you'll get a box notifying you that you're downgrading. Click through it and the process should run without issue. I've been back and forth between 1.4.16 and 1.5 several times now.0
I have noticed that I need to run the AGC-T at a lower setting than the knee, more like 30. After a lot of listening and testing I get better results by tuning to a spot with no stations, turning on the WNB and sliding the AGC-T to the left "slowly" until the noise is blanked out. I have opened multiple slices on the same frequency so as to see the difference in the dbm reading between the slice with the WNB active and the one without. Hope this helps.0
Bill, you got it, there is a sweet spot that you can find slowly and easy to miss.0
I don't really hear a difference when adjusting the WNB. I do however notice a difference in noise level when using the NR.
Thanks Bill. I gave this a try and all that happens is that the receive gets quieter as the AGC level is moved left. The power line noise is still very easy to hear and see in the panadapter.0
Then your noise is uncorrelated (aperiodic) and NR is the proper mitigation feature to use.0
Hello Mike- Since the blanker is software perhaps sending in a video with sound to FRS they can improve your situation. Lets hope the blanker performance gets better over time.1
Is there a reason that DIGU/L doesn't include NR?0
Good idea, Bill. I'll get that done tomorrow. I'm shut down for the night due to thunderstorms in the area.0
I've not been able to get any conclusive effects of the new wnb. It worked once on a very wide band noise I sometime have on 160m but for my regular 80-40-20m noises the nb in 1.4.16 was more useful to me. Yesterday I've compared the NB on my icom ic-7100 to the flex on 1.5 to get rid of a 80m noise and the flex wasn't able to match the icom in noise removal like I was able to do with 1.4.16. I've played a lot with the agc, the wbn level and it's either way too complex to fine tune or it doesn't work properly on my setup.0
My Yaesu FT-2000D works better on noise reduction than the flex 6300 which does nothing on noise reduction.
You noise is not well correlated which is what the WNB operates on. We are looking into adding a slice level NB to SmartSDR in an upcoming version.1
It looks like that is going to be a good idea, Tim. All noise is not created equal. Apparently one great tool doesn't work on all noise sources. I am having good luck on many, if not most, of my noise sources. I like it! But there are a few (I have many neighborhood sources) for which the older style on the 1500 worked more effectively. Options are power.
- 250 Community Topics
- 489 The Flea Market
- 7.4K Software
- 332 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 779 Maestro
- 42 FlexControl
- 732 Genius Products
- 254 Tuner Genius XL
- 86 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 586 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
