cw filter snaps back to +/- 500hz in v1.5.0.65
Asher - K0AU
Asher - K0AU Member ✭✭✭
edited March 2020 in Third-Party Software
CW filter bandwidths work normally with the 50/100/400/800 buttons.  Click the 1.5 or 3.0 buttons and the filter bandwidth reverts to +/-500 Hz.  Drag the filter skirts past 500 Hz and they revert to 500Hz.
Interesting detail: when I click the buttons below 800 the filter is set up symmetrically.  Click the 1.5 button and the filter "tries" to go to -600/+900 before reverting to +/-500.  The 3.0 button "tries" for -600/+2400 before reverting to +/-500.
Am I missing some new configuration?  I skipped over v1.4.
Config is v1.5/6700/Win10
  • Doug Hall
    Doug Hall Member ✭✭
    edited February 2017
    I'm not seeing the issue with the filter reverting to +/-500 Hz here. Flex 6300 SSDR v1.5.0 Win7. But I do see the asymmetric behavior (eg. -600/+900) with the wider filters, and I think that's normal. In my case I have the CW offset (pitch) set to 600 Hz, so with a 1500 Hz filter I can't go +/- 750 as you would expect. If I change the pitch to 750 Hz then I see +/-750 Hz on the 1500 Hz filter.
    So the asymmetry is expected behavior with the wide filters, but snapping back to +/-500 Hz is not.
    Doug K4DSP
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Asher, are you using DXlab ?
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    Hi Asher,
    Are you running DXLab Commander or any other rig control program?  If so, shut it down and try again.  (I had a similar problem due to DXLab Commander which Dave is in the process of fixing.)
    73, Bob, N7ZO
  • Asher - K0AU
    edited March 2020
    yes
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    edited December 2016
    oops, I see Sergey beat me to this while I was typing.
  • Sergey R5AU
    edited September 2015
    This is well known commander issues, you can check it
  • Asher - K0AU
    edited March 2020
    You guys are fantastic!  Shutting down DXLab solves the filter issue.
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    Dave, AA6YQ, the author of DXLab, is testing a new version of Commander that solves this problem.  Stay tuned.
  • Asher - K0AU
    edited March 2020
    Any published time frame for the fix?
  • Sergey R5AU
    edited April 2017
    No yet, but Dave promised to fix it asap
    BTW some other issues also exist with Commander for now
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    Don't know on the time frame.  Dave recently changed Commander to connect directly to the Flex 6000 radios over TCP/IP (no more need for a CAT com port).  He is also testing this.
    edit:  Sergey is faster again.  :-)
  • Sergey R5AU
    edited April 2017
