Questions about API 1.5 changes
edited February 2017 in FLEX-6000 Signature Series
Hello,
I read SmartSDR changelog document and I have the following questions moslty related to API modifications.
#2326    API: References to NB are now WNB.  Old NB references will remain temporarily for compatibility
Does it mean that the related commands in the future will be changed from
        slice set %d nb=%d
        slice set %d nb_level=%d
to
        slice set %d wnb=%d
        slice set %d wnb_level=%d
And what is the variable name in the typical slice status message?
        ... enb_level=**** wnb=x ...
#2241    API: Added RFGain field to FlexLib Slice class
In my 6300 I can set the rfgain level from the panadapter object. Does this mean than now I will have an analogue command for each slice? I am thinking to something like
         slice set %d rfgain=%f
#2229    API: RF PreAmp can be be change from the Slice level
The same question as in the previous point. If it is possibile, can you provide status messages and related new commands?
I have also a question about normal usage of WNB filter: during the first usage I found that the WNB indicator lights from light gray to white. What does it mean?
This is already answered in a previous post from Walt.
Welcome!
  • Administrator, FlexRadio Employee admin
    I believe the answer is yes to all your questions.  Except the one reference to enb_level should be wnb_level (but I think this is likely just a typo).
  • Member ✭✭
    edited December 2016
    Thank you for you answer Eric,
    actually enb_level it is a typo.
    In the mean time I sniffed some packets and I have found a further property called wnb_updating.
    S4C8957CA|slice 0 nb=1 nb_level=23 wnb=1 wnb_level=23
    S4C8957CA|display pan 0x40000000 nb=1 nb_level=23 nb_updating=0 wnb=1 wnb_level=23 wnb_updating=0
    S0|display pan 0x40000000 nb=1 nb_level=23 nb_updating=1 wnb=1 wnb_level=23 wnb_updating=1
    I suppose it reflects the WNB processing status or similarly the annunciator status (0=off-light grey, 1=0n-white) I can see in SSDR panadapter.
    Can you confirm it?
    Thank you very much for you help.
    73' Enzo
    iw7dmh
    Exactly.  Good guess.
