Questions about API 1.5 changes
IW7DMH, Enzo
Hello,
I read SmartSDR changelog document and I have the following questions moslty related to API modifications.
#2326 API: References to NB are now WNB. Old NB references will remain temporarily for compatibility
Does it mean that the related commands in the future will be changed from
slice set %d nb=%d
slice set %d nb_level=%d
to
slice set %d wnb=%d
slice set %d wnb_level=%d
And what is the variable name in the typical slice status message?
... enb_level=**** wnb=x ...
#2241 API: Added RFGain field to FlexLib Slice class
In my 6300 I can set the rfgain level from the panadapter object. Does this mean than now I will have an analogue command for each slice? I am thinking to something like
slice set %d rfgain=%f
#2229 API: RF PreAmp can be be change from the Slice level
The same question as in the previous point. If it is possibile, can you provide status messages and related new commands?
I have also a question about normal usage of WNB filter: during the first usage I found that the WNB indicator lights from light gray to white. What does it mean?
This is already answered in a previous post from Walt.
slice set %d nb=%d
to
slice set %d wnb=%d
I believe the answer is yes to all your questions. Except the one reference to enb_level should be wnb_level (but I think this is likely just a typo).0
Thank you for you answer Eric,
actually enb_level it is a typo.
In the mean time I sniffed some packets and I have found a further property called wnb_updating.
S4C8957CA|slice 0 nb=1 nb_level=23 wnb=1 wnb_level=23
S4C8957CA|display pan 0x40000000 nb=1 nb_level=23 nb_updating=0 wnb=1 wnb_level=23 wnb_updating=0
S0|display pan 0x40000000 nb=1 nb_level=23 nb_updating=1 wnb=1 wnb_level=23 wnb_updating=1
I suppose it reflects the WNB processing status or similarly the annunciator status (0=off-light grey, 1=0n-white) I can see in SSDR panadapter.
Can you confirm it?
Thank you very much for you help.
73' Enzo
iw7dmh
Exactly. Good guess.0
