Band change from tab panel in SSDR 1.5 stops working
edited March 2017 in SmartSDR for Windows
Upgraded to 1.5 SSDR with no errors or issues reported during the process.
I have noticed today that the band TAB buttons don't change the band. If you're on 40m LSB and click 20m then you loose the SLICE RX but the radio does not move. You need to double click the fft window to return to where you were operating.
No band buttons work after changing the band to the "dead space". The active SLICE stays on where you were in the tool-bar.
Memories work fine - you can jump about without any issues.
I have not reset nor cleared any settings or profiles.
Welcome!
  • Member ✭✭
    edited December 2016
    That's odd as mine works fine and I have not done anything other than install SSDR 1.5
    Bill
  • Member ✭✭✭
    edited March 2017
    A reset often works wonders...
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Yes, it sounds like you have an issue in the band persistence database that needs to be cleared using a factory reset.
  • Member
    edited September 2016
    Correct, nothing software wise helped - a power-on "purple light" reset cured it.
    Might be worth noting?
    Cheers Steve
