Band change from tab panel in SSDR 1.5 stops working
Steve Walker
Upgraded to 1.5 SSDR with no errors or issues reported during the process.
I have noticed today that the band TAB buttons don't change the band. If you're on 40m LSB and click 20m then you loose the SLICE RX but the radio does not move. You need to double click the fft window to return to where you were operating.
No band buttons work after changing the band to the "dead space". The active SLICE stays on where you were in the tool-bar.
Memories work fine - you can jump about without any issues.
I have not reset nor cleared any settings or profiles.
That's odd as mine works fine and I have not done anything other than install SSDR 1.5
Bill
A reset often works wonders...
Yes, it sounds like you have an issue in the band persistence database that needs to be cleared using a factory reset.1
Correct, nothing software wise helped - a power-on "purple light" reset cured it.
Might be worth noting?
Cheers Steve
- 685 The Flea Market
