Difficulty installing FreeDV waveform
Guy Kowalski
Can't install the FreeDV waveform program on my Flex 6500. I downloaded the .msi file and then double clicked on the file which installed the program in Windows. The red Icon is on the Windows 7 Desktop screen. In Smart SDR I opened the File menu and clicked on the Waveform Manager . I then clicked the Install button which took me to the Waveforms Folder where the FreeDV.ssdr_waveform file was located. I selected that file then clicked the Open button. The "FreeDV' title shows up as installed in the Waveform Manager list. I also noticed a small window popped up on the lower right saying that there was a connection to an IP address. Their is no "FDV" button on the Slice Flag . I have read the other threads and they are of no help.
Your slice A has to be in FDV mode before you open the FDV applet.1
Thank you Tim, I will give that a try.0
Thanks Tim, I was having trouble too... That fixed it for me...0
Tim,
How do I put slice A in FDV mode if the FDV does not show up as a selection on the slice flag?0 -
Are you running SmartSDR 1.5 ?? if not it wont show up...0
Yup, I am running 1.5 version of SmartSDR0
Guy,
Did you execute the download file? The instructions are to remove the previous version of FreeDV app and waveform, run the executable ( http://www.flexradio.com/downloads/smartsdr_freedv_waveform_installer-exe/ ) , then open the Waveforms under "File" and install the waveform .. Start the FDV app, and select FDV as the mode in SmartSDR, A slice only..
There is a How To also .. ( http://www.flexradio.com/downloads/freedv-waveform-how-to-guide-pdf/ )
Hope this helps..
I followed the steps exactly. A new waveform name appears in the Waveform Manager labeled FreeDV v1.0.3 but FDV never appears as a mode in the Slice mode list.0
You might want to do a help tickets? Imagine it is a simple tweak somewhere. 73 Steve. K9ZW0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
[{"insert":"Did this get resolved. Having the same problem here on Win 10.\n"}]0
David,
As of now the FreeDV API is not functional, you need to now FreeDV on your computer using DAX for in/out audio and SmartCAT forPTT control. The most used FreeDVmode is 700d, which the app has not kept up with .
Dudley
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
