Difficulty installing FreeDV waveform
Guy Kowalski
Guy Kowalski Member ✭✭
Can't install the FreeDV waveform program on my Flex 6500. I downloaded the .msi file and then double clicked on the file which installed the program in Windows. The red Icon is on the Windows 7 Desktop screen. In Smart SDR I opened the File menu and clicked on the Waveform Manager . I then clicked the Install button which took me to the Waveforms Folder where the FreeDV.ssdr_waveform file was located. I selected that file then clicked the Open button. The "FreeDV' title shows up as installed in the Waveform Manager list. I also noticed a small window popped up on the lower right saying that there was a connection to an IP address. Their is no "FDV" button on the Slice Flag . I have read the other threads and they are of no help.
    edited March 2017
    Your slice A has to be in FDV mode before you open the FDV applet.
  • Guy Kowalski
    edited September 2015
    Thank you Tim, I will give that a try.
  • Corey/ KC0YNS
    Corey/ KC0YNS Member
    Thanks Tim, I was having trouble too... That fixed it for me...
  • Guy Kowalski
    edited May 2019
    Tim,
    How do I put slice A in FDV mode if the FDV does not show up as a selection on the slice flag?
  • dlwarnberg
    dlwarnberg Member ✭✭
    Are you running SmartSDR 1.5 ?? if not it wont show up...
  • Guy Kowalski
    Yup, I am running 1.5 version of SmartSDR
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    Guy,
    Did you execute the download file?   The instructions are to remove the previous version of FreeDV  app and waveform,  run the executable  ( http://www.flexradio.com/downloads/smartsdr_freedv_waveform_installer-exe/ )  , then open the Waveforms under "File"   and install the waveform ..    Start the FDV  app,  and select FDV as the mode in SmartSDR,  A slice only..
    There is a How To also ..   (  http://www.flexradio.com/downloads/freedv-waveform-how-to-guide-pdf/  )
    Hope this helps..
  • Guy Kowalski
    edited March 2017
    I followed the steps exactly. A new waveform name appears in the Waveform Manager labeled FreeDV v1.0.3 but FDV never appears as a mode in the Slice mode list.
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited November 2016
    You might want to do a help tickets? Imagine it is a simple tweak somewhere. 73 Steve. K9ZW
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • David Oppenheimer
    [{"insert":"Did this get resolved. Having the same problem here on Win 10.\n"}]
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    David,
    As of now the FreeDV API is not functional, you need to now FreeDV on your computer using DAX for in/out audio and SmartCAT forPTT control. The most used FreeDVmode is 700d, which the app has not kept up with .
    Dudley
