Serial Port Needed
joe camilli
I am in search of either a usb to serial or a PCI or PCIe serial card that supports all serial port pins and uses 12 volt on the pins. The reason for the request is I have a LDG 200PC tuner that I recently figured out why I was have issues with it. Turns out the unit was designed to respond to -9 to +9 volts on the RTS line. Most newer serial ports do not support this voltage. Hooked it up to a old laptop with a single serial port and it work every time. I would like to get a port for my main computer Thanks Joe N7QPP
Look at Startech.com, they have several different varieties of PCI-e RS-232 cards for good prices, Also Black Box but there stuff is more expensive, and I think SIIG make these cards.
You can also just build a level converter with a couple transistors a 7909L (-9V), 7809(+9VLV) voltage regulators, a AC wall wart, a few electrolytic Cap's, a full wave bridge rectifier and perfboard one together.
73's
Bret
WX7Y
I bought on on Amazon. I think it was around $12 with, as I recall, a 5' cord.0
If you go the USB-Serial route and are using windows, I would stay away from converters using the Prolific chipset. There are many driver issues with these that aren't worth the aggravation. I always use converters based on the FTDI chipset. A little more money, but way more stable under windows.
Jon...kf2e1
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
