Is there a way to change DAX in use other than the pull down?
Kg5dwx
Does anyone know of a way to make an icon switch for changing DAX in use. I use the a FLEX 6500 in MARS, you may be voice, with DAX set on DAX1 for MT63, then rapidly change to DAX3 for M110A or DAX 2 for RMS winmorP2. Having to use the very small pulldown is a real difficult action when in a hurry. It would be great to have a small window like FRstack or even better just click in the DAX audio control on the requested DAX if it is displayed (I always have it up so I can see which DAX I am on and levels). Anyone have an idea? Can it be done in DDutil?
Flex, this would be appreciated if added to DAX control panel.
Rodney Warner
Rodney Warner
Can you use multiple slices and just change the slice TX designation?
Thanks Tim0
Rodney,
I don't know if this will work with the programs that you wish to use. I assume that they seem to required different TX level setting and that is why you wish to use different DAX channels..
You could try using the same DAX channel ( with one DAX TX level setting ) for all three programs and then balance the TX audio levels in the WIndows audio mixer for DAX TX1
Good luck.
AL, K0VM
Al, I was just trying to make it more difficult than I needed to, thanks for a fresh view.0
Hope it works for you.. I have not tried it myself.. The slide for a program may not appear in the mixer until after you have transmitted once with that program after booting the PC.
AL, K0VM0 -
It works, with MixW, rms winmor and ms-dmt all on the same DAX , each with its own com for PTT. Thanks for the insight.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
