Is there a way to change DAX in use other than the pull down?
Kg5dwx
Kg5dwx Member ✭✭
edited November 2017 in SmartSDR for Windows
Does anyone know of a way to make an icon switch for changing DAX in use. I use the a FLEX 6500 in MARS, you may be voice, with DAX set on DAX1 for MT63, then rapidly change  to DAX3 for M110A or DAX 2 for RMS winmorP2. Having to use the very small pulldown is a real difficult action when in a hurry. It would be great to have a small window like FRstack or even better just click in the DAX audio control on the requested DAX if it is displayed (I always have it up so I can see which DAX I am on and levels). Anyone have an idea? Can it be done in DDutil?
Flex, this would be appreciated if added to DAX control panel.
Rodney Warner
  • Tim - W4TME
    edited March 2017
    Can you use multiple slices and just change the slice TX designation?
  • Kg5dwx
    Kg5dwx Member ✭✭
    edited February 2017
    Thanks Tim
  • Al K0VM
    Al K0VM Member ✭✭✭
    Rodney,
      I don't know if this will work with the programs that you wish to use.  I assume that they seem to required different TX level setting  and that is why you wish to use different DAX channels..
      You could try using the same DAX channel ( with one DAX TX level setting ) for all three programs  and then balance the TX audio levels in the WIndows audio mixer for DAX TX1
    Good luck.
     AL, K0VM
  • Kg5dwx
    Kg5dwx Member ✭✭
    Al, I was just trying to make it more difficult than I needed to, thanks for a fresh view.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Hope it works for you.. I have not tried it myself..  The slide for a program may not appear in the mixer until after you have transmitted once with that program after booting the PC.
    AL, K0VM
  • Kg5dwx
    Kg5dwx Member ✭✭
    It works, with MixW, rms winmor and ms-dmt all on the same DAX , each with its own com for PTT. Thanks for the insight.
