dogparkSDR - MAC OS/X client for FlexRadio 6000 series
Great remote client audio function. Using Beta 63
Too bad. if so, it just might be enough to get me to buy my first MAC! for right now, it is Win10....
But I would LOVE to have something that ran under Linux Mint...
There is a transmit button in the HUD and we are running Mac audio in and out in Beta 631
Running 66 on MacBook Air from Paris via VPN to radio in La Jolla. V1.4.24 Furmware
First time I started it with Mac Audio enabled everything worked great. Very good alternative to my iPad remote
Second time I started it...No Panadapter Frames Received. Audio still worked ok
Running DDUTIL on home PC to control SteppIR, Amps and Wattmeter
YES. I need the Swiss Army Knife
What is might be the cause of no Panadapter display the second time?0 -
Use the contextual menu to make sure you have at last one slice and have a look at the Debug Log for errors (File Menu Show Debug Log)0
It's 4 am. Here now. Will do that when I wake up today.0
Interesting... the Beta is a free download to try, and when I paid for a subscription the update was a 1.**** series software ! Been playing with this all evening and it sets up easily, has a very nice bandscope/waterfall, and interfaces perfectly with MacLoggerDX for DX spotting, maps, and logging. FINALLY there's a completely Apple Mac OSX version of software for our beloved Flex-6000 series radios ! (I have a new Flex-6300 and no relationship to Dogpark software) Cheers... Bob KK8ZZ
Doesn't Don list the software as Beta 1.0 and then release say 0.80?
Steve K9ZW
Here is what I grabbed as a screen shot:
Been experimenting with
dpSDR v1.00 b80 and mldx and extra-cluster and cocoamodem running in osx 10.10.5
and
with DAX and sdrbridge and cwskimmer running in VM v8 win7
all on i7 mini with multiple monitors
extra-cluster is a program Don developed to read post from cwskimmer and place them in mldx. this allow for mldx to get posts from your local cwskimmer and from the wider inernet clusters at the same time
pic below i snapshot from two monitors
also
used mldx keyer feature with macros to key flex6300. My setup includes a winkeyer usb. This is a good substitute for CWX. You get macos and can send live cw and still use the key itself too.
Don is doing some awesome work to bring the flex to the mac community
Paul K3SF
Runs fine on El Capitan here ! Beautiful waterfall, and click and tune is great !
Bob KK8ZZ
Hi Paul, I'm running just about the same thing - nice work! Funny that a whole Windows VM is there for DAX. How are you getting audio to/from CocoaModem? I have co-opted the single audio pair from Parallels and mapped it to DAX1 and the optical audio on my Mac. Not a perfect solution, but it works.0
i use the following process to route audio about
a combo of soundflower and audacity
rightnow only doing copy..have not tried to transmit yet
see details here
http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_mac.html
Don...I'm having a blast with your beta's.
One nagging issue....When dragging the panadapter right or left significantly away from the current pass-band +/- 50 KHz or so, the panadapter will snap back to the current selected frequency of the pass-band. You have to set intermediary frequencies less than 50 KHz to move up or down the band. This is not intuitive and slows performing a QSY to a frequency up or down significantly in the given band.
Is there a work around or am I doing something wrong? Thanks in advance!1 -
Fixed in Beta 93, Thanks for catching it0
Thanks Don. I've loaded Beta 93 and it works as you would expect. Thanks a bunch for your awesome support!0
Hi Don, any plan on making pan scrolling be like SmartSDR or Stu's app where the spectrum and WF move together? We are so used to that now. Your is scrolling like classic PowerSDR and other normal apps. We get quite spoiled by such small, but hugely impactful features.1
New bug....If you have DogParkSDR running and then start MacLoggerDX, everything is fine. If you quit DogParkSDR and attempt to restart it without first exiting out of MacLoggerDX, SDR will timeout and display the "No Panadapter Frames Received". You must exit completely out of MacLoggerDX before DogParkSDR will successfully connect back to the radio. The same problem exists if you were to start MacLoggerDX first, before connecting successfully with DogParkSDR.
Just trying to be a good beta tester for you Don.1 -
Since I was down to one digital audio channel anyway, thought I'd go for broke and leave Windows entirely. With Don's latest beta, you can select "Mac Audio" audio inputs/outputs. I wired (fibered?) the optical ports together and use them instead of DAX. Works like magic after a little tweaking (put all my ports at the same bitrate and bandwidth - 2ch, 26 bit, 48k).
Thanks Jay, it's a known bug mentioned on the web page:
- Note: If you use MacLoggerDX and dogparkSDR on the same Mac you will need to run dogparkSDR first.
It's on the list0
Thank you. Funny as it may sound, that plays a large part in my purchasing decision. I'm a GUI guy!0
Fixed in Beta 94 (still needs some work though)0
Don,
I have put an old MacBook pro into use and works well. Is there no TX equaliser yet?
Andrew
No, but it's on the list0
Don
I am really excited about this software. I downloaded it a couple of weeks ago and then got beta 93 last night and made a few remote contacts. Great job!
Continues to work great on the 2015 MacBook... now just need the VPN stuff1
Don, you are software development machine! 100 builds in a little over 2 weeks. Phenomenal! That's the reason I plopped my money down tonight. Your continued efforts to bring a "best of class" SDR client interface to the Mac OSX platform is so very much appreciated.3
Don,
I don't know is this feature is on your list, but it could be nice to adjust the frequency in the Panadapter with the mouse (scrolling the mouse wheel up or down for fine adjustment). Thanks Jean-Luc / F5JRC0 -
I'll see what I can do, but I highly recommend the FlexControl for Tuning etc.0
Thanks Don. I made my first contacts with dogparkSDR, away about 50 meters from the Flex6500 on the LAN network, and logged in MLDX, magic!
Just a little fear about SWR which cannot be checked… later maybe… 73's Jean-Luc0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 874 Genius Products
- 313 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 136 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
