Contest Configuration
Asher - K0AU
Member ✭✭✭
It’s that time of year. Time to think about contest season configuration. I've run my Flex in a custom LAN Remote setup since I got it two years ago.
https://dl.dropboxusercontent.com/u/6673719/K0AU%20Block%20Diagram%20v2.0.pdf
Figures 1 and 2 show my hardware. I use the RemoteRig RRC1258 boxes for remote audio and keying. For remote serial ports I use Moxa serial servers.
Figure 3 shows my everyday DXLabs configuration.
Figure 4 shows my N1MM+ CW contest logging configuration. Last year I found the Flex remote CWX feature doesn’t support the ESC key to stop sending. I added a remote K1EL Winkeyer to resolve the problem. However this configuration means I can’t use the Flex LAN Remote audio feature, because it doesn’t carry CW sidetone. So stuck with the RemoteRig boxes for now. Fortunately I like the paddle keyer in the RR box. Not shown: an old numeric keypad and Hotkey Manager that handles the exchanges. I operate with the right hand on the FlexControl, the left hand on the numeric keypad and jump to the keyboard in the middle to type in call signs.
Figure 5 shows my understanding of a Maestro configuration. I’m not clear if it coexists with SSDR, but I don’t see the utility in my station until it does.
Figure 6 shows my experiments with CW Skimmer. I found it to be fragile and not well integrated with other tools.
What about DDUtil? I’ve dabbled with DDUtil but haven’t found it solves any problems I really have. There are enough fans around I’d like someone to explain how it would make my life better.
I need to experiment a bit with LAN Remote for SSB contesting. Does anyone know how N1MM+ voice keyer audio and LAN Remote audio work together?
We’ve heard from the Dayton announcements that Flex is focusing on contest workflow. It would be great to see a block diagram of how they anticipate the various software packages will integrate and how they will talk to some of the semi-announced 4O3A accessories. Would love to hear if anyone has better ways to configure and run their Flex stations.
Hi Asher, nice post, how do you like the OB9-5 and do you have a Alpha 9500 and what Expert Amp. do you have?
Tim Hill - KI6LSB0 -
I like the OB9-5 a lot. Extremely well designed and well built. Optibeam's Tom DF2BO is incredibly responsive and helpful. SIde benefit with the Flex is I can monitor multiple bands.
I have a OB9-5 just got it all put together and it is going up next Wednesday, Tom is a great Guy and help me alot.0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
