Can't export profiles
N3NER
Has anyone run into this? Whenever I try to export profiles or settings in any way, it sets there for a close to five min and when it finally completes, its an empty file..
I have never seen this happen... More info as to SmartSDR version, Win version might be helpful
73s Jim K4JAF
SmartSDR is 1.4.16 running on windows 7 64 bit.0
If you can't export profiles, then you have a corrupted persistence database. Export your profiles, but UNCHECK the preferences option. Do a factory reset of the radio. Test the profile export, it should be working. After that import the preferences free profile export to get back the TX and global profiles, but not the persistence part of the database.0
I did a factory reset in troubleshooting my HRD issue so, that I did already. Still not working. Anything else I can try?0
Make sure you did not import a previously exported profile set before testing the export after the factory reset. That would copy the bad data back into the persistence DB that is causing the issue,
If you did that, then look to see what program(s) on your PC would be preventing a file from being created on your desktop. Disable all virus scanning or Internet security suites.0 -
Tim, you are the man! It was my virus protection stopping it... Thanks!!0
Your welcome.1
- 323 Community Topics
- 577 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
