Ham Radio deluxe will not Key 6300
N3NER
I just noticed that HRD will not key the flex at all from HRD, all the other buttons seem to work fine but not the TX button. I also have a VM with windows 7 on it and installed HRD and the same thing, will not key up the 6300. I'm running windows 7 on both the VM and my Dell 790, my VM is running on a IMAC 27 using parallels. I know at one time this did work but all of a sudden dead.
Anyone run into this?
Well I just re-flashed the firmware to 1.4.11 and it worked fine, I re-flashed it back to 1.4.16 and it stopped working. Sooo
Flex support, there is a problem..... With firmware 1.14.16.... I'm going back to 1.4.11 for now.
Tim, this need to be put in the the next version for a fix...
Have you tried this: https://community.flexradio.com/flexradio/topics/smartsdr_ham_radio_deluxe_dm780_howto_setup_guide HRD works better if you create a PTT port and use this instead of keying with a CAT command. I'm in Oban, Scotland at the moment without any of my ham equipment and can therefore not be of more help. 73, Alex DH2ID0
Yes i did try that and it did not help. Only when I down leveled the firmware is when the problem was resolved. This was happening on three computers so this must be a firmware issue.0
I don't think it is universal though as I am using a 6300 (1.4.16) with the latest HRD (6.3) and PTT works fine (I use a separate CAT PTT port). Having said that, I am tending to use DDUtil mostly now as SmartSDR makes the HRD Rig Control app largely redundant....0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
