Ham Radio deluxe will not Key 6300
N3NER
N3NER Member ✭✭
I just noticed that HRD will not key the flex at all from HRD, all the other buttons seem to work fine but not the TX button.  I also have a VM with windows 7 on it and installed HRD and the same thing, will not key up the 6300.  I'm running windows 7 on both the VM and my Dell 790, my VM is running on a IMAC 27 using parallels.  I know at one time this did work but all of a sudden dead.
Anyone run into this?
  • N3NER
    N3NER Member ✭✭
    edited March 2018
    Well I just re-flashed the firmware to 1.4.11 and it worked fine, I re-flashed it back to 1.4.16 and it stopped working.  Sooo
    Flex support, there is a problem.....  With firmware 1.14.16....  I'm going back to 1.4.11 for now.
    Tim, this need to be put in the the next version for a fix...
  • DH2ID
    DH2ID Member ✭✭✭
    edited December 2016
    Have you tried this: https://community.flexradio.com/flexradio/topics/smartsdr_ham_radio_deluxe_dm780_howto_setup_guide HRD works better if you create a PTT port and use this instead of keying with a CAT command. I'm in Oban, Scotland at the moment without any of my ham equipment and can therefore not be of more help. 73, Alex DH2ID
  • N3NER
    N3NER Member ✭✭
    Yes i did try that and it did not help.  Only when I down leveled the firmware is when the problem was resolved.   This was happening on three computers so this must be a firmware issue.
  • Phil M0VSE
    Phil M0VSE Member ✭✭
    edited September 2016
    I don't think it is universal though as I am using a 6300 (1.4.16) with the latest HRD (6.3) and PTT works fine (I use a separate CAT PTT port). Having said that, I am tending to use DDUtil mostly now as SmartSDR makes the HRD Rig Control app largely redundant....
