SSDR and a clean Win10 install
Randy Diddel
Hi,
I have just ordered a 6300. I have a good solid machine ready and waiting for the arrival of the 6300. Installing Windows 7 or Windows 10 are options (MSDN subscription). I know Windows 7 would be OK. The downside of Windows 7 is that it will take a long time to download and run the updates released since SP1. But my real question is: Has anyone done a clean install of Windows 10 and had issues? I have seen many posts about in place upgrades having issues but nothing definitive about those with clean Windows 10 instances.
/randy
/randy
Worked fine here. Congrats & enjoy!
Dear Randy - I have 2 Flex 6500 radios - each with it's own pc - performed a clean windows 10 install and then installed my Flex Radio software - no problems whatsoever - these 2 machines were running Windows 8.1 - I downloaded the ISO file and setup bootable DVD's and a USB Drive and performed the usual format and clean install - you will love your radio - it keeps on getting better and better!!0
Good to hear. I've gone the upgrade route (8.1 to 10) but still not completely happy with SSDR and all the associated programs running. That's why I've been waiting for feedback from others - and if it works 100% I'll see no reason not to go for it.
Jeff - G4IUA0 -
Works just fine here too!
Gerd, W2ISB
I have updated three machines from 8.1 and another from 7. No problems with any of them. My SSDR machine was Windows 7. I completely uninstalled SSDR, removed all associated directories, removed all VSP ports and DAX drivers. I ran CCleaner to get all the strays out of the registry. I upgraded and then re-installed SSDR. Everything came up and has been working fine for about a week now.
Given a choice between 7 and 10, I would pick 10. The logic is that all future drivers and things are going to be designed for the new software. If you don't want the learning curve of learning the new Windows 8/10 menu schema, get a free program called Classic Shell and your start menu will look just like Windows 7.
Steve
Upgraded the laptop here from 8.1 to 10, did a clean install on it with no problems at all. On the main desktop upgraded from win 7 to 10 with no problems. I did completely removed all SSDR programs, ports, etc beforehand and then reloaded them after the upgrade.. Only problem was my internet speed dropped drastically after the upgrade but must have been outside network problems as after a day or so, came back just to what it was before (I do have slow DSL here).
Enjoy the 6300, great radio for the $$$$... 73s Jim K4JAF
Randy,
I would advise you to read this before you do a clean install of Windows 10. Apparently Microsoft say that you should do the normal upgrade path to Windows 10 first, as if you do a clean install first, then your product key might not be detected.
http://www.theverge.com/2015/7/31/9077997/microsoft-windows-10-clean-install-how-to-guide
73's Andy F5VAI
ndy,
Not really an issue as I have a M$ MSDN account and will be using full install ISO's not upgrade bits.
/randy0 -
Thanks everyone! I consider this answered.
/randy0 -
I'm running a 6500 on a Win10 box that got a clean install last week. All is well with the radio and the client software. No problems with DAX or CAT. I'm running SSDR over DXLabs and under WSJT-X and FLDIGI.
I am working around some Win10 bugs related to the use of Homegroups. My interpretation of the problem is that the existence of a Homegroup clobbers the permissions on Documents, OneDrive, Videos and Pictures folders. The problem is probably much more complex and subtle than I've described (they usually are). This problem has been widely reported.
My workaround for the present is to simply do without Homegroups. I expect to see this problem evaporate in the next month or so as fixes come down.
Otherwise, all running very well.
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
