flex control stopped working
Bill Carnett
Bill Carnett Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
Was working fine, with the exception of having to unplug/plug in from time to time.  Today I upgraded SDR 1.4.16.  After a couple of false starts, got that problem fixed.  Now noticed Flex Control not working.  Profiles said "not recognized go to troubleshooting" or something close to that.  Looked on Device manager, COM 99.  Said "device is working properly." Changed the port to 107 (why not?).  Rebooted.  Still no change.  Suggestions?  I'm glad I don't have to pay for my questions.  Thanks all. 73, Bill AH6FC/7
  • George KF2T
    George KF2T Member ✭✭✭
    Try toggling it in the setup menu (the FlexControl button in SSDR setup). Think it's a bug being worked by the Flex team.
  • ka7gzr
    ka7gzr Member ✭✭
    edited February 2017
    I have the same problem since loading .16.
    Jim
    ka7gzr
  • Bill Carnett
    edited March 2017
    Any progress on this problem?  Toggle doesn't work.  It lights up when I turn on but the Flex Control is still not recognized....whereas it used to work fine before software upgrade.
    73, Bill
    AH6FC/7
  • K0UNX
    K0UNX Member ✭✭
    edited June 2016
    After installing Windows 10, I started SSDR and went to SETTINGS, then FLEX CONTROL.  You have multiple choices for each button, so I set Aux 1 to TUNE Active Slice, Aux 2 to Master AF, and Aux 3 to MOX.  They’ve been working perfectly.  Of course, you may want other choices for the buttons.
  • Tim - W4TME
    edited December 2016
    Yes, we are making progress on this issue.  Improvements will be included in the next release of SmartSDR.
