Windows 10, ACLog and WSJT
Bob Brown - N8OB
I installed Win 10 from Win 8.1. ACLog and WSJT were working in 8.1 but I can't get them to interface in Win 10. Nothing seems to connect. Has anyone had any luck with either of these programs? Win 10 controls the Flex 6300 without a problem. I have tried different port settings but it either indicates the port is in use or does nothing. Device manager show the ports as greyed out.
Can anyone help?
Can anyone help?
I had a lot of trouble getting CAT to work and ended up doing a complete uninstall and reinstall of SSDR. Just uninstalling CAT didn't seem to be enough. The broken com ports could be seen using device manager. But while it was broken CAT itself appeared fine and communicated with radio but WSJT was returning a Hamlib error, and all other apps that used Cat also failed. I reckon that one old version of SSDR was not uninstalled as advised before the upgrade.0
Bob - I downloaded from Microsoft the Windows 10 Iso file and setup both a bootable USB Drive and a DVD - I performed a clean install on both my Flex Computers - all went well - I installed Windows 10 on 5 computers - there is ample directions on line to help us all along!!0
Bob - you should do a complete uninstall of SmartSDR before you upgrade to Win10.https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSD....
You can try a complete uninstall and then a reinstall of the SmartSDR ecosystem and see if that helps.
I'm using SSDR and AClog with Win10. Virtual ports are a pitfall, but do as Tim says and
all should be well.
Ned, K1NJ
I uninstalled all files related to SSDR (which I didn't do before upgrading to Win 10) and my ACLog program is working again. Now I will play with WSJT-X as my next project. It doesn't pay to upgrade without checking out all the caveats. At least I am moving in the right direction.
THANKS to all for comments and things to check.
WSJT-X is rather odd when changing settings to try to make it work, you need to close and restart it or it seems to give the errors even though it is correctly configured. This is my configuration.
Installed the latest Win 10 update and ACLog no longer interfaces to the Flex.
- 375 Community Topics
- 105 SmartSDR+
- 427 SmartSDR for Mac
