Is Direct connection to computer fixed in latest version 1.4.16
Ed Brenner
I am currently running version 1.4.3. This requires that the radio be cabled to the computer via my cable /wifi box. Does the latest version cure the problem so you can cable direct to the computer?
If your problem's root cause is what we addressed in 1.4.11, then yes that defect was resolved0
Not sure what your change was in Version 1.4.11. In the version I am running it was an IP address problem when connecting direct. I guess that it was taken care of in version 1.4.11 which I never downloaded. So I should be able to connect direct if I down load the latest and greatest , Correct?0
Install 1.4.16 first, update the firmware and then try the direct connect. That is the safest way to proceed.0
Thanks for the answer, and quick turn around! I am a fairly new operator ( but old 61) and throughly enjoying it. It really helps when I run into a problem and have a radio that the people stand behind. Thanks ED KM4HPN0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
