power supply current Variation over time ?
Marc Lalonde
Hi
i notice something on my 6500 on fresh power-up Radio in idle RX take ~4A
after 2 - 3 day on normal operation it Start to increase to reach up to 10A and remain to 10A
also i notice that on TX on 6M current was way over the specified 23A to reach near 35Amp
so did other have note similar Thing ??
73 Marc VE2OLM
73 Marc VE2OLM
Marc: I would be worried about seeing 35A on 6m. That kind of current usually indicates a significant RF mismatch in the PA section. I would try the following:
1. Transmit into a dummy load that is good for 50MHz.
2. Adjust your output power (TX) while noting the ammeter on your power supply.
There is an internal fuse at 30A in the radio so I'm also suspicious you may be getting RF into your power supply metering circuit.
If it doesn't look right, I would suggest you open a helpdesk ticket and let the folks at Flex take a look at your rig.
Have a good weekend!
Greg - K5GJ
Hi
just validate and on dummy load still take around 35A on TX whatever the band
i take measure from my Astron RS-35M Meter ,not have a clamp meter that haled 30A
but that the idea to ask here for see if i need to put hand on decent current meter or it normal
i not think i pick up RF in shack , radio was Gronded whit 1" copper strap that go to 3 x 10 feet ground ROD
Best 73 Marc VE2OLM0 -
I don't see anything like that on mine. Do you have anything else drawing current on that power supply that might be drawing current during key down. I.e... Tuner or something else . I agree with Greg that's a lot of current for what you are doing. I'd be making the help desk call for piece of mind if nothing else Mike N9DFD0
Greg is correct, this is not normal behavior.
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0 -
The metering on your power supply is highly suspicious. Use a good ammeter and reevaluate.0
Hi TIm
Did it about TX current or the increase of idel current ?
since in TX i may have doubt on the meter but on RX that puzzle me
Best regard0
- 339 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
