When I try Pactor/RMS express/Smart SDR The radio transmits and acts correct but no signal out, on
edited September 2017 in SmartSDR for Windows
I am using a DR-7400, COM 10 in CAT, transmit light on red but pandaptor show low signal. Mike on ACC.
Welcome!
  • Member ✭✭
    edited February 2017
    Is DAX button on?
  • Member ✭✭
    I turned my Dragon audio up to 2200. Seemed to work. However, I have not been consistent connecting to anything with the MODEM. MODEM works well on TS-2000.
  • Member ✭✭
    edited December 2016
    Dax off
  • Member ✭✭
    I'll check the dragon audio, worked great on ft-857, thanks.
  • Member ✭✭
    edited July 2015
    Try Dax On
  • FlexRadio Employee ✭✭
    In order to run PACTOR with the 6000 series radios there are a couple of things that have to be in place:
    1. The slice used for PACTOR must be in DIGU or DIGL with a filter wider than 3k. This will make SmartSDR use lower latency filters to decrease turnaround time.
    2. Make sure the audio levels are set properly. The MIC level meter should peak right under 0.
    3. Although you can use AGC with PACTOR on some paths you can save a few milliseconds of latency by setting the AGC to OFF.
    4. Make sure PROC and the EQ are off as well.
  • Member ✭✭
    This works
    Flex:
    DIGIU at 5K
    Mike=ACC
    EQ=off
    PROC=off (Default on DIGIU)
    DEXP=off (Default on DIGIU)
    Set Comport you are using to Active in CAT
    RMS Express:
    TNC setup:
    PSK=4000 (max)
    FSK=4000 (max)
    TX delay 0 to 20
    Radio:
    Radio - Flex
    Band USB DIGITAL
    Seems to work!
    Rodney H. Warner
    KG5DWX
    512-496-4301 cell
