Flex 6500 with SCS DR-7400 Pactor.
Kg5dwx
Thanks for your help on my earlier post, I have the SCS on the ACC port with the SCS cable, Now transmitting at a reasonable level In RMS express I an using PSK-850 FSK-850 to get good transmit levels. TX delay I have tried from 5 to 40. Never connects, trys but never links up. Is anyone else using a SCS DR-7400/7800 with the Flex. Please, any help welcome and appreciated!
Rodney
Austin
KG5DWX
512-496-4301.
Rodney, Travis seems to have got his P4Dragon working:
https://community.flexradio.com/flexradio/topics/pactor_p4_dragon_release_1_2_17
Travis should be W3TMB, you could answer his posting or look him up on QRZ.com and send him an email.
I have used this article:
http://kc.flexradio.com/KnowledgebaseArticle50422.aspx
to build a cable for my Flex-3000 and PTC-IIpro, which works quite well.
I plan to use this wiring diagram to build a cable for my Flex-6500 and PTCIIpro.
Can't say anything about the P4 Dragon - yet, as I don't own it.
What sort of cable are you using? I don't see anyhing abot FlexRadios on the
SCS page and would be interested to know where you can buy one.
My PACTOR stations are:
IC-756 and PTC-II at the DL0KHZ Karlsruhe club station
IC-756PRO and PTC-IIpro at my DH2ID home station
FT-897D and PTC-IIex at my mobile/portable station
All these setups are also used for EMCOMM in the German
Amateur Radio Emergency network.
I am still experimenting with SDR's for PACTOR use, but I have
trouble with TX delay and latency.
I will therefore keep my "old" TRXs running. I especially love the
ICOM radios, as they are PIN diode switching and you hear no relay
clicks....
Sorry, but that is all I can tell you. I someone here has a P4 dragon running
with a Flex-6000 series TRX, I would also be very interested to know the
setup, wiring diagram and RMSExpress settings!
73, Alex DH2ID0 -
FWIW, Have run my 6500 with RMS Express using the WInmor TNC, The Winmor TNC consistantly reports a TX>RX turnaround in the 300-500 msec range. I haven;t used a hardware PACTOR but my guess is that the TX>RX turnaround is tighter for PACTOR than Winmor. The turn around in the Flex radios can mostly be traced to the DSP in the radio. IF latency is the issue, you are likely to heard the other station respond to your transmission but the connect attempts are unsuccessful.
YMMV
AL, K0VM
In order to run PACTOR with the 6000 series radios there are a couple of things that have to be in place:
1. The slice used for PACTOR must be in DIGU or DIGL with a filter wider than 3k. This will make SmartSDR use lower latency filters to decrease turnaround time.
2. Make sure the audio levels are set properly. The MIC level meter should peak right under 0.
3. Although you can use AGC with PACTOR on some paths you can save a few milliseconds of latency by setting the AGC to OFF.
4. Make sure PROC and the EQ are off as well.
Thanks to all, this one worked. Does any one know if you can turn up the gain on the ACC port?0
This works:
Flex:
DIGIU at 5K
Mike=ACC
EQ=off
PROC=off (Default on DIGIU)
DEXP=off (Default on DIGIU)
Set Comport you are using to Active in CAT
RMS Express:
TNC setup:
PSK=4000 (max)
FSK=4000 (max)
TX delay 0 to 20
Radio:
Radio - Flex
Band USB DIGITAL
Seems to work!
Rodney H. Warner
KG5DWX
512-496-4301 cell
I'd like to resurrect this discussion to see if anyone else has solved the riddle of the Pactor modems with the Flex Signature series?
My Flex 6500 will key up and TX what appear to be clear tones (using monitor) through the SCS PTC-IIpro modem. It is connected to the radio with the cable provided by Farralon Electronics and it is made for the Flex 6500. I've tried the exact settings found in several posts here, as well as some variations of the settings. So far, I have been unable to make a Pactor connection. I can hear the distant end responding but the Flex never seems to "pick up the phone" in response. I'm afraid that if I can't get this working, I may have to put the Flex on the used radio market and pick up another IC-7300 (which works just fine with the modem). Is there anyone else that's gotten this combination to work together?
Craig
N0CSM
P.S. Winlink/Winmor works as well as Winmor can work.
is there a commercially made cable that one can buy to interface between modem and Flex 6300 ?
Andy K3UK0 -
I would recommend calling the US dealers, http://www.farallon.us/webstore/ I didn't find a cable here in Germany and therefore had to build one myself. That was quite easy, just a bit soldering. ..0
I emailed the Canadian dealer and they have no cable to suggest, they are looking in to the issue for me. They have never had a request for cables to interface a Flex 6000 series radio.
The US dealer sold me mine, I may have one laying around as I don’t use it with the flex any longer.Email me at rhwarner@me.com
Rodney H. Warner
AAA6RD
U. S. Army MARS
512-496-4301 cell
- 339 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 367 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
