When I try Pactor/RMS express/Smart SDR The radio transmits and acts correct but no signal out, on
Kg5dwx
I am using a DR-7400, COM 10 in CAT, transmit light on red but pandaptor show low signal. Mike on ACC.
Is DAX button on?0
I turned my Dragon audio up to 2200. Seemed to work. However, I have not been consistent connecting to anything with the MODEM. MODEM works well on TS-2000.0
Dax off0
I'll check the dragon audio, worked great on ft-857, thanks.0
Try Dax On0
In order to run PACTOR with the 6000 series radios there are a couple of things that have to be in place:
1. The slice used for PACTOR must be in DIGU or DIGL with a filter wider than 3k. This will make SmartSDR use lower latency filters to decrease turnaround time.
2. Make sure the audio levels are set properly. The MIC level meter should peak right under 0.
3. Although you can use AGC with PACTOR on some paths you can save a few milliseconds of latency by setting the AGC to OFF.
4. Make sure PROC and the EQ are off as well.
This works
Flex:
DIGIU at 5K
Mike=ACC
EQ=off
PROC=off (Default on DIGIU)
DEXP=off (Default on DIGIU)
Set Comport you are using to Active in CAT
RMS Express:
TNC setup:
PSK=4000 (max)
FSK=4000 (max)
TX delay 0 to 20
Radio:
Radio - Flex
Band USB DIGITAL
Seems to work!
Rodney H. Warner
KG5DWX
512-496-4301 cell
- 113 SmartSDR+
- 920 Genius Products
