Can the Flex 6500 connect safely to the AL-80B with out an interface?
KD4Y
From the AL-80B manual...
"Requires contact closure or sink of +12 Vdc at 100 mA"
From the Flex Manual...
"+40 VDC @ 140 mA maximum"
So yes, it should be safe to connect directly.
Jon...kf2e
Thank You Jon!0
Working for nine months without a problem.0
Yes.
Dan0 -
FWIW...
But the AL80B manual does not say that there is not an inductive kick from a relay coil. Such a kick could easily go beyond 40vdc.. But I have don't have one nor do I have I access to the schematic to tell for sure.
AL, K0VM
Tim's response on another post
Tim - W4TME, Customer Experience Manager
Here is my advice. Always use a buffer relay regardless of the amp. It will be some of the best $40 insurance you ever buy for your radio.1
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
