How to specify filter in lower sideband using Filt API?
Dave AA6YQ
The ethernet API command
filt <slice index> <low_cut_hz> <high_cut_hz>
always places the filter in the upper-sideband. Reversing <low_cut_hz> and <high_cut_hz> causes the command to be ignored.
How does one place a filter in the lower sideband using the ethernet API?
Try using negative numbers?0
Yes, that is the way to do it. Just multiply the lo cut and hi cut by -1 for LSB.
Thanks guys, that works. I've updated the wiki page with this information.0
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
