How to specify filter in lower sideband using Filt API?
Dave AA6YQ
Dave AA6YQ Member ✭✭
edited June 2020 in SmartSDR API
The ethernet API command
filt <slice index> <low_cut_hz> <high_cut_hz>
always places the filter in the upper-sideband.  Reversing <low_cut_hz> and <high_cut_hz> causes the command to be ignored.
How does one place a filter in the lower sideband using the ethernet API?
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    Try using negative numbers?
  • Carl Moreschi
    Carl Moreschi Member
    edited July 2015
    Yes, that is the way to do it.  Just multiply the lo cut and hi cut by -1 for LSB.
  • Dave AA6YQ
    edited July 2018
    Thanks guys, that works. I've updated the wiki page with this information.
