60 meters on the 6300
N3NER
N3NER Member ✭✭
edited March 2018 in FLEX-6000 Signature Series
I just got a new 6300 and sold my Icom.  I have used 60 meters in the past and it seems 60 meters is disabled for TX.  How can I get this opened up?
  • N3NER
    N3NER Member ✭✭
    edited March 2018
    I tried all the modes and the TUNE and MOX button stay grayed out, the only mode it does not stay grayed out is CW.
  • Tim - W4TME
    edited December 2016
    What is your call or QTH Nick?
  • N3NER
    N3NER Member ✭✭
    W2NER
  • N3NER
    N3NER Member ✭✭
    Oh, and my QTH is Hopewell junction NY
  • Tim - W4TME
    edited August 2017
    All radios sold in the US have the 60m band enabled.  However, you must be within a designated channel in order for TX to be enabled.  I suspect your slice is tuned to a frequency that is outside of the 60m channel.
  • Jean Drolet
    Jean Drolet Member ✭✭
    edited September 2017
    Tim,  i have the same problem i live in canada at 5.370mhz 60m it's not activated
    http://www.rac.ca/rac-0-30-mhz-band-plan/
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2017
    Double check your TX bandwidth.  It should be less than 2.8 khz
    Cal/N3CAL
  • Jean Drolet
    3000khz it's ok thank's :)
  • Brian_KF4IRE
    Brian_KF4IRE Member ✭✭
    So I have the same problem. I have double checked the frequencies, USB, 2.7 width, under 100w and it still doesn't enable. Haven't tried CW but that's not what I want to try 60m with. So, my assumption is I need a ticket open too? Any other suggestions?
    Please post a screen shot of SmartSDR while you are on 60M.
    • what VFO frequency?
    • Your High and Low pass Mic settings
    If your TX doesn't enable, you are somehow 'out of band'.
