Radio Not in List of Radios
I have a CW memory keyer program that uses FlexLib. I have a user (FLEX-6500 user) who reports that my program cannot find the radio. I have a FLEX-6700 and have never seen this problem.
Anybody have any suggestions about why the API.RadioList collection would be empty?
My code captures the RadoiAdded & RadioRemoved events to update the list of radios displayed to the user.
73, Ray, K9DUR
This is a user not on your lan? The way radios are discovered and hence added is via a UDP broadcast. If the radio is not on the same lan segment your software won't see it. Or if this user has your software and his radio on different lan segments it still won't see it. What's the lan segment the software is on and the lan segment his radio is on. Also, if the radio is off or just powering up, it won't see it.0
Are you supporting both versions of the Discovery protocol?0
Ray download your keyer and it connected to my 6500 sent CW just fine. Can I be of any other assistance?
Tim, I am using The FlexLib API.RadioList collection to get the list of radios. Also, I am capturing the RadioAdded & RadioRemoved events to update the list. So, I am using whatever discovery protocol that FlexLib is using. 73, Ray, K9DUR0
We changed discovery protocol versions in 1.2. What version of SSDR is the operator using? If it is an older version, the radio will not show up.0
Tim,
He says he is running v1.4.11. I got his report just before you released v1.4.16 to the public.
73, Ray, K9DUR
I have some additional info from my user. He does not have a router. His computer is connected to the internet via the Ethernet adapter on the motherboard. He added another Ethernet adapter to connect the radio. Therefore, I suspect my program is trying to find the radio using the wrong adapter.
So, how do I resolve this?
73, Ray, K9DUR
Honestly, he should go buy an Ethernet switch connect it to the Internet router and then the PC and the radio to the switch and not use the ethernet adapter.
Otherwise, I this this is a question for Eric.0 -
Thanks, Tim. I will so advise him. -- 73, Ray, K9DUR0
- 349 Community Topics
- 615 The Flea Market
- 8K Software
- 2 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 207 FLEX-8000 Signature Series
- 921 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 138 Contesting
- 754 Peripherals & Station Integration
- 973 Third-Party Software
