Flex 5000A Flexwire HF band data
Steve
Does the Flexwire data stream include the band data for the HF bands? If it does - I'd like to use one of K3TUF's interface boards to control the Low Pass Filter board on my home brew HF amp.
No, PowerSDR does not have logic for reporting HF bands via I2C from the FlexWire port.0
Then how does the Heros HF presellector get its tuning data? Seems to me that HF band data is exactly what it needs in order to operate correctly. Perhaps there's something else going on?
Thanks in advance for your response.
73 Steve KG4LJB.
Steve,
You can use the FlexWire board on HF by using DDUTIL. You will have to change the address on the board, but that works on HF.
Phil0 -
Phil,
I am trying to find an alternative to using DDUTIL. After considerable effort - I cannot seem to get it to auto load - either with Power SDR or with windows, and when manually loaded, frankly it seems buggy and unstable.
I had hoped to buy an interface board from you (but I guess you are not getting my email) and skip DDUTIL altogether by getting the needed HF band data from the Flexwire connector.
I'm wondering if it would be possible to tap into the I2C clock and data lines of IC30 (the device that controls the 5000A's low pass filter relays) and send that data to an outboard PCA9555PW set for the same address. This should mimic IC30's output precisely, and give me the control data I need.
If you still have Flexwire interface boards for sale, I'd like to buy one!
73 - Steve KG4LJB
Steve - I did the PowerSDR code maintenance for the past 4 years and there isn't any other alternatives I know of unless you want to modify the PowerSDR code to output I2C commands on HF band changes.0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
