LoopA and LoopB in Panadapter.cs
James Whiteway
Looking thru Panadapter.cs I find the above listed and cannot find what they connect too.
(meaning what value(s) they return to the client, if any. So far, I can get the StreamID, LowdBm,
HighdBm and the bandwidth of the current panafall. But, still cannot find the actual arrays of data for the panadapter itself.(and I can set LowdBm, Center Frequency, HighdBm, bandwidth etc. just fine) In Vita.VitaFFTPacket.cs there are several things that look like they should return the values I'm looking for. But, I cannot seem to get the syntax right to get them.
And "intellsense" in Visual Studio (2010 in this case) does not show several things that appear in VitaFFTPacket.cs at all. So, I'm thinking that what I am seeing there is private to that class and not readable. (at least not in the format that I think I need)
So, still stumbling around a bit. What a fun way to spend Father's Day! Hope everyone had a good day with family and friends.
james
james
James,
LoopA and LoopB refer to the filter/preamp loops that exist on each SCU - one (A) on the 6500, two (A +
on the 6700. There is no loop on the 6300.
If you enable the loop (set to 1), the antenna signal is routed out via loop out on the rear panel and back in via loop in. I don't know whether the loop is before or after the bandpass filters - I am guessing before (and probably likewise the protection diodes).
I'm not familiar with C# (other than code reading FlexLib ;-) but it looks to be that you have to set yourself as a delegate of the Panadaptor stream (DataReadyEventHandler) which is called when a full panadaptor frame is ready for processing. Its called from Panadaptor.cs via (I think) the DataReady event being triggered with the Pan object and the array of pan data.
Stu K6TU0 -
Thanks Stu, I kind of figured that Panadapter.cs did not have everything I needed to get the additional pan info. I'll keep plugging along!
james
James.
The Panadaptor does have everything you need - however, you do need to be able to set your client as the delegate for the panadaptor to call when data arrives. Sorry I can't help you further with how to do that in C#.
However, you might take a look at this documentation from Microsoft...
https://msdn.microsoft.com/en-us/library/aa288459(v=vs.71).aspx
Stu K6TU0 -
My bad Stu, I reread what you said and see you pointed me in the right direction. Eric confirmed what you said as well, in another thread. I will read the document you linked to. Maybe, I will get it then. Thanks for not giving up on me! james WD5GWY0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
