intermodulation distortion
Bill Carnett
Today while operating on 6 meters I noticed considerable distortion from strong local stations. These guys were strong but not terribly so. Typically I could control it with use of my filters. However hearing clicks and signal blocking (sorry that's not the proper engineering term) up to 8 khz away. One guy had a bad signal, at least close by, but most were nice clean CW signals. Yes I was using the pre-amplifier, but this was 6 meters and signals were weak. Not sure there is anything else to do. Never had this problem with my icom-756 pro III. However, it absolutely could be something I am doing/not doing correctly with the Flexradio. Any advice is welcome.
73, Bill
AH6FC/7
73, Bill
AH6FC/7
Did you have your Noise Blanker on?
Jim, K6QE
Bill,
I have had horrible intermodulation once with a fractured centre conductor to PL259 centre pin solder joint. No effect on TX SWR etc. So check your feed line connections.
Andrew
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
