intermodulation distortion
Bill Carnett
Bill Carnett Member ✭✭
edited February 2017 in FLEX-6000 Signature Series
Today while operating on 6 meters I noticed considerable distortion from strong local stations.  These guys were strong but not terribly so.  Typically I could control it with use of my filters.  However hearing clicks and signal blocking (sorry that's not the proper engineering term) up to 8 khz away.  One guy had a bad signal, at least close by, but most were nice clean CW signals.  Yes I was using the pre-amplifier, but this was 6 meters and signals were weak.  Not sure there is anything else to do.  Never had this problem with my icom-756 pro III.  However, it absolutely could be something I am doing/not doing correctly with the Flexradio.  Any advice is welcome.
73, Bill
AH6FC/7
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited June 2015
    Did you have your Noise Blanker on?
    Jim, K6QE
  • Andrew VK5CV
    Andrew VK5CV Member ✭✭
    Bill,
    I have had horrible intermodulation once with a fractured centre conductor to PL259 centre pin solder joint. No effect on TX SWR etc. So check your feed line connections.
    Andrew
