Headset/Mic for 1500
Mike NA5U/K5D/K1N
I wonder what, if any, is/are the preferred headset/mic/s
for use with a 1500, i.e. a plug and play?
Mike, NA5U
Mike. I use the Yamaha CM500 headset, I think it is great. It has a wonderful mic with a wide response. and the price is hard to beat.
Bill,
Thanks so much! The CM500 seems to be a favorite for many. I'll be getting on on order.
I use a Heil ProMicro with the Yaesu adapter, I also own a cheapie (AudioComm) I bought on eBay I use with a W2ENY adapter, both work great. Interesting enough, I seem to get more praise about my audio when using the cheapie
. The key is to spend ample time adjusting your eq no matter which mic you choose 0 -
The Heil BM-10 HC5 works well with a bit of EQ. The latest model might need a bit more. Lower sensitivity of the earpieces is better as there is some amp hiss audible with the more sensitive ones.
Fellows,
Thanks for all the the great information.
Mike, NA5U
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
