freeDV
Bob G W1GLV
i need explicit info getting my 6500 to run with freeDV
What have you tried so far? Is there a particular problem you're running into?0 -
I have installed FreeDV on my Win 8.1 computer and rebooted several times. Free DV does appear as an installed application but "FDV" does not show up in the Mode Selector window. I have a Plantronics USB headset/mic plugged in. What am I missing? Thanks and 730
Bill, FreeDV is installable waveform which is downloadable from Flex radio Systems. Click on Support and Downloads. Here you will see a selection for SmartSDR for Windows. Click on it. Then you will see a Waveform selection, click on it. There you will see the installer for Free DV. Download it an install it in your SSDR folder. Now you should see FDV as a selection in Mode selection.0
Got it working. Thanks. Still have some more learning to do but right off the bat, I listened to crystal clear DV on 14.236. Amazing!
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
