Android App
I added filter marks on the tune display. A light opaque fill is between the lines. Here is a quick video showing how they work and look. Please excuse the bad video and the noise. My son is playing his video game on a plasma TV. URRGGHH those things are noisy!!!
https://www.youtube.com/watch?v=hx568FYttz4
3 -
Well it certainly looks like you got over the problems you were having trying to work out how to do a waterfall a few weeks ago. There seems to be no stopping you now
Very nice, indeed!
I heard a story of a plasma that was installed at a contest station before anyone knew what they were like. When one of the ops decided to sit an watch TV for a little relief, the station owner yells "Hey who turned on the lawn mower!?!"0 -
LOL, it really destroys all bands. Its the worst thing I have encountered. He is not allowed to turn it on on contest weekends
But I'm to cheap to replace it LOL. Luckily its just in his game room for occasional gaming. The rest of the TV's have been replaced with new LED.
William
These videos do not do the waterfall justice. For some reason video cameras, wash out the waterfall colors, and over expose it. The waterfall really looks good in person.
Here is an HD video. Colors still washed out, but better representation. Audio you are hearing is DAX. Still no luck with OPUS. But DAX sounds real good.
Near the end of the video I am adjusting the MAX/MIN dbm which in my app adjust waterfall gain/black level.
Here is a screenshot that better captures the Panfall display
6 -
Looks great, William, but should say Panafall...;-)0
Doh!!
I just through stuff on the screen. Not much rhyme or reason behind the layout now.0 -
hey william, will i be plugging my CMD micro into the android ??
great job !
No, although I could make that happen, Its not exactly practical.
William
Looking at your spectrum display, it appears that each pixel in the display is repeated twice with the same value. Are you telling the radio your correct display size and then correctly plotting what it sends you?0
Steve, Good eye, but still wonder how you saw that. This is due to scaling. I currently have a static X value or 1400, but my display is 2560. I am just scaling the data to fit my screen.
I do however plan to eventually request the the panadapter x value base on actual screen pixel width, but just haven't gotten around to it yet.
Still wondering how in the world you could tell from the photo..LOL
William
Oh you know how it is -- you work with something a long time you can spot all kinds of things other people would miss.0
Since I have your attention, I'm trying to get DAX TX working. For some reason I just cant get it to work..
I form the payload of floating point -1:1. I can play this data with the same decoder that is currently working to listen to DAX from the radio.
But for some reason the radio just does not seem to like it! I created a VRT header with these hex bytes:
18d501078400000000001c2d543c03e3000000000000000000000000
Then append 1024 bytes of floating points.
I then send this to the radio on UDP 4994 (this is the port I use "client udpport 4994")
I have verified dax=1 in TX setting, dax_tx=1 in slice settings,
and dax channel is set. But when I MOX I get no output at all.
I forced the UDP packets to the IP of my computer and was able to
decode them fine. Is there something in the VRT header that I'm
missing? I just copied the header used by DAX on my PC.
Wireshark classified my packets as VRT49 with correct class and stream ID, so I'm lost.
Any ideas?0 -
Its gone awful quiet here, hope all is well William...I updated my tab4 to lollipop the other day in eager anticipation..hihi
Cheers
Paul
gi4fzd0 -
To be honest, I have stalled out a bit on the Audio portion. DAX RX works, but I can't seem to get TX to work. My question above has gone unanswered.
I have not given up, just taking a step back and working on other projects for a bit
Great stuff. I hope you will get the answer soon.Keep up the good work,an rx only version would nice too.
cheers
Paul1 -
We have a debug command to find out what the issue is, but it's not available in the code you have unfortunately. It would identify what is happening to your VITA-49 packets. We could look into making this code available somehow in the production code in the future, but I don't have a real good solution today.
Also, DAX is really the wrong way to do transmit code. We will be adding an uncompressed TX/RX port for mic audio soon though. This could be used instead of Opus if you like.2 -
Steve,
Very interesting! Will this be a feature of 1.5 or before? When you say uncompressed, will this be PCM or Floating point?
William
Hi Guys,
Can one purchase a copy of the app as I would like to use it on my galaxy tab2 10" tablet via wifi or bluetooth to control the powerSDR software. Please contact me via my email address
thanks
Sometimes you need to walk away for a bit as you get to a point you can't see the wood for the trees. Inevitably on return the solution immediately presents itself usually accompanied by a slap on the forehead and calling oneself a muppet for not seeing it earlier.
You've gone a very long way in a short amount of time.0 -
Thanks! Yes I have stepped away and decided to spend my time building an engine instead. I will get back to it again shortly.
Also kind of waiting to see what Steve was talking about above on a new uncompressed audio that will be coming out.
3 -
I hope your engine is done.
Engine is done, but I'm still waiting on this new uncompressed audio solution Steve was talking about. I have hit a wall with opus William1
William, Great see you back, we missed you. Hope you're your R&R was good!0
Hi William, nice to see you back here, love your pawprint ;-)
C'mon you opus programmers, help William to get his app ready....
I had a look here http://opus-codec.org/ , but I'm not much of a programmer,
did a bit of JAVA but not much more.0 -
FYI we have the uncompressed audio working in the lab now, but it is designed primarily for use by a logger or voice keyer. It uses something like 40x the bandwidth of Opus. For a remote app, I recommend using Opus.0
William, Is the Opus codec included in Android 5.0 any good for an intermediate solution until you get yours up?0
The android OPUS has very little documentation. I am unable to get it to work. Maybe once the documentation catches up.
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 34 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 929 Maestro
- 903 Genius Products
- 326 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 982 Third-Party Software
https://www.youtube.com/watch?v=wUcqbSBuAg8
