FM Squelch - is it my imagination is there a lot of break-thru noise occurring erratically?
Roy Laufer
I am having loads of fun playing with my DEMI 2M LDPA connected to my 6700. It's educational, looking at Repeater signals come and go throughout the day.
I have noticed that the squelch is broken during random background noise without any radio activity. Am I just not fine tuning the squelch settings enough, or is the squelch algorithm in need of some software "tweaks" in a later release.
Also, are there any plans to add a squelch control for non-FM modes?
Thanks!
Roy, AC2GS
Thanks!
Roy, AC2GS
Roy: I have noticed the same thing. If I turn the squelch up enough, it seems to stop. I have planned to put a signal generator on the unit to see what the levels are, to see if it is a real problem, or if the adjustment just has too much range. . --Mike, WV2ZOW0
I entered a similar problem report just after getting FM on my 6700. It seems there is a build-up of (something) that causes the squelch to break and then reset. Adjusting the squelch changes the delay between breaks then stops them entirely.0
I have entered this problem report into our bug tracker for additional investigation. Thank you for the defect report.
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
