Tune power indication with SmarSDR v1.4.11
Bernie
I am running SmartSDR v 1.4.11 on Windows 7 with a 6700. In the radio setup page I have the Tune Power set to 10 Watts. However when I select Tune the 6700 does indeed deliver 10 Watts, but the Power Slider continues to indicate 100% while in the Tune state.
I believe someone else mentioned this.
-73-
Bernie
W4BGH
-73-
Bernie
W4BGH
Your observation with the tune control is correct. The tune pwr bar indicates the tune power, the above RF power is the power of the radio in a mode other than tune. I think it has always been this way if my memory is correct. Jim K4JAF
One of the reasons I find the TUNE power and and RF Power useful is that when I want to tune my SB-200 tube amplifier for a band - I want to start out tuning at a low power level of 5 watts to get the load and tune controls on my amp close before I run it at full 30 watts (all I need to drive my amp to 600w PEP).
Meanwhile, I can just leave my RF Power control on SmartSDR at 30 because when I go to SSB mode (or other modes) it will use THAT 30w power level and get me my 600w PEP.
And then I set my TUNE power back a bit if I need to retouch the tuning quickly without overheating my 572b tubes too much - saves the tubes and elongates their life.
The Tune and RF power is the same as it was in PowerSDR and is useful. Just like Jim said - the RF power control is for when you go into a mode OTHER than tune.
---Gary WB8ROL0
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
