Tune power indication with SmarSDR v1.4.11
Bernie
Bernie Member
edited January 2018 in SmartSDR for Windows
I am running SmartSDR v 1.4.11 on Windows 7 with a 6700.  In the radio setup page I have the Tune Power set to 10 Watts.  However when I select Tune the 6700 does indeed deliver 10 Watts, but the Power Slider continues to indicate 100% while in the Tune state.
I believe someone else mentioned this.
-73-
Bernie
W4BGH
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    Your observation with the tune control is correct.  The tune pwr bar indicates the tune power, the above RF power is the power of the radio in a mode other than tune.  I think it has always been this way if my memory is correct.  Jim K4JAF
  • Gary L. Robinson
    Gary L. Robinson Member ✭✭
    edited February 2016
    One of the reasons I find the TUNE power and and RF Power useful is that when I want to tune my SB-200 tube amplifier for a band - I want to start out tuning at a low power level of 5 watts to get the load and tune controls on my amp close before I run it at full 30 watts (all I need to drive my amp to 600w PEP).
    Meanwhile, I can just leave my RF Power control on SmartSDR at 30 because when I go to SSB mode (or other modes) it will use THAT 30w  power level and get me my 600w  PEP.
    And then I set my TUNE power back a bit if I need to retouch the tuning quickly without overheating my 572b tubes too much - saves the tubes and elongates their life.
    The Tune and RF power is the same as it was in PowerSDR and is useful. Just like Jim said - the RF power control is for when you go into a mode OTHER than tune.
    ---Gary WB8ROL
