Android App
Thanks!
Strictly speaking I didn't mean cast it, more wrap it. In the case of Android, I don't believe you can do that. You may have to create a bitmap from those values using the BitmapFactory.decodeByteArray(data, 0, data.length) and then draw the bitmap.
Ok Guys, I should have a version to test by Monday
Its far from done, but if you have a 10" android tablet, your welcome to test what I have so far. You must enable developer mode. Copy the apk to your tablet and install. If you don't know how to side load apps on android, please Google it!
Also, please don't post that it doesn't work on your phone or 7" tablet. I already know that LOL. This only works on 10" screens. And not even 100+ sure it will work on all 10" screens
AGC fast/slow/med/off buttons not yet mapped. Neither is the lock or +RX button. All else should be working.
The slider above the large tune wheel is to set dial sensitivity. All the way to right is less sensitive, all the way to left is more sensitive. I suggest you use larger step if you want to move fast, and leave the sensitivity slider as low as you can and still easily tune without overshooting. It takes a little getting used to, but once you get used to it, its easy.
Initial radio discovery will cause a small pause during app load. This a side thread, but the UI can't continue until an IP is returned. If the app locks up and never loads, then it can't find your radio.
Let me know the good and the badBut please don't ask how to load it. Google it
https://www.dropbox.com/s/3vvwcf82xkper3w/app-debug.apk?dl=0
William
If you were referring to me William, I only have a Nexus 9 I am using for my development. Come about 95 the world pretty much shifted away from **** clients (that would be standalone apps like OS/2 PM and Windows MFC) in favor of thin clients (that would be browser based apps). While, at that time, I did little in the UI space, beyond a couple years immediately following 9-11 when I did an incredibly spiffy http browser hosted multi-tabbed applet for a company in St Louis. Since that time I have done multiple HTML-5 enterprise applications. So it's been a while since I've done a **** client. The trick is designing a completely portable foundation library that will work on all platforms. Beyond that it is just wiring the pieces and building the web services. Android (and iPad) pose some unique challenges but incredible opportunities that are best left to release time.
William, my tablet is a Samsung SM-T800 10,5" AMOLED-Tablet and of course the buttons are not in the right place on the screen (2506x1600 pixels).
But the tablet recognizes my 6500 at once and MOX/VOX/Tune etc. buttons work! Great!
Maybe one day there will be a version for 10.5" tablets ;-)
BTW I found this:
http://developer.android.com/guide/practices/screens_support.html
73, Alex DH2ID0 -
Alex the layout is landscape. Open the app while the the screen is in landscape mode. The App locks the orientation on open. So make sure you open it while its in landscape mode.
If you open the App while the screen is in portrait, this happens. It should work fine on a 10.5". This is a bug I have yet to resolve.
But for now, turn turn that sucker sideways and relaunch the APP LOL
William
William, we all had a good laugh here!!! Of course...turning automatic
screen orientation off did it!
Now it looks great.
You can tell that I'm a better ham than android op!!!
73 and thanks a lot,
Alex DH2ID
Reinstall this version, it forces landscape mode. If you open in portrait, it will auto switch to landscape.
If you like reverse landscape, as in some tablets (like mine) have the **** usb on the bottom, so to use it on a stand, I need reverse landscape.
Anyway if you want reverse lanscape, just open the app in while in that orientation. If you open in any other orientation, it will now switch to regular landscape to avoid the portrait mess in Alex's pic above
Forcing landscape did it for me. Now even I have an uncluttered screen.
I know how to make it work with multiple screen sizes, i just have not made the effort yet. I will get around to it once I'm happy with the operation.
William
Of course getting the app to work with multiple screens is not easy,
because resizing and scaling can cause bad effects with fonts etc.
It must be quite late in the night on your side now 8-)0 -
More like early morn
. Back to bed for me
Anyway, play with the App and let me know how its working.
The App should now also work on 7" tablets, albeit the controls will be smaller. But your welcome to try it. https://www.dropbox.com/s/3vvwcf82xkper3w/app-debug.apk?dl=0
All Buttons are now mapped, so all onscreen functions should work now. Also anyone with a 7" android tablet. Let me know if it works.
William
Fantastic job. Loads on the 7" tablet with no issues. NR and ANF worked in the earlier version, appears to be not working in this version, so are the sliders for each. The text for Main Vol is cut in half, still readable. A suggestion, TX Low and TX High are not commonly used, that real estate be allocated to something else.
I was unable to install it on a 10" Asus tablet, parsing error, but loads fine on the 7" tablets.
73 and thanks,
Karl
KB2AS
This version works on my Samsung S T-800 10,1" Tablet.
Looks good, all buttons work, runs stable.
Although the knobs look great I would prefer sliders, as they occupy less space
and are easier to set than knobs. You could then put the TX filter slider below
the RX filter one. I think a long slider at screen bottom occupying the whole screen width would be great for frequency tuning and addition of a RF power slider or knob would be great also.
For those who prefer knobs to sliders an option to change them could be a solution.0 -
Let me go borrow my son's 7" and I'll get it working. I personally use the TX high low often. But open for suggestions on what to put in its place that would get used more.
Also for the parse error on your 10", make sure you have at least Android version 4.3. If not it will not work. In about device is the settings menu, it will tell you the version. And most likely an option to auto update.
William
I found the issue with the 7"layout. Your 7" must have a software navigation bar at the bottom. This cause objects linked to the bottom of the frame to get distorted and or pushed up. Your tune dial is probably oval also
I will have to do some more tweaking so I can get objects are not affected on tablets with an onscreen nav bar.
This copy has an updated 7" layout. Everything works and looks fine on my 7"
Works great on my 7" Nexus 7 tablet. It's a bit cramped for some of the controls. Might go to Best Buy and get one of the $79 10" tablets they have. Otherwise, fine job. As I stated about the USB controller software, you are very prolific in development. A simple to use Android app is what I had in mind (along with a couple of other things). You have beat me to it and done a good job!
Congratulations on a job well done!
james
Forgot to add, I like the knobs. Looks really cool and a bit old school too!1 -
Good deal. Gad its working for you. Its been a fun project. I'm slowing leaning more and more each day.
One quick question. What is the slider above the tuning control for? I move it and do not see or hear, any changes. Other than that, it seems everything works good.
james
Yes its really meant as for a 10" or larger. I built it for myself, as a project. I'm in the processing of learning, and doing this really helps. Love the feedback, as it increases the learning process.
The slider above the main tuning wheel, controls the sensitivity of the dials. All the way to the right is less sensitive. All the way to the left is more sensitive. Sliding it all the way to the left allows you to tune faster, but up makes the dials very touchy, When its too far left, its hard to tune an exact freq. Your likely to overshoot.
Set it to a level that makes it easy to not overshoot your desired frequency. And then just use step sizes if you want to move fast.
Willaim
Cool ! Makes sense now. Is there a label for the control that might be covered up on my 7" tablet?
james
No there is no label for that0
This is a really cool App and you made a lot of progress in short time! I am blown away... Runs on a Nexus 7 w/o any problems.
A minor nit-pick would be the NR and NB are swapped compared to the S-SDR UI.
I am also using Sound Wire to deliver audio to the table so now complete receiver control / listening ability is possible.
An ask on my part would be to add CW mode button.
A huge ... HUGE ... ask is to add a SWL mode, that is toggle out the ham bands buttons to give the SWL bands. Perhaps adding the SAM mode selection and make that selection change the bands from ham to SWL.
Then, any other mode selection (USB / DIG etc) would revert back to the Ham bands.
Did I mention great job? !
Thanks for posting the APK.
Best,
Tim
- 311 Community Topics
- 567 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 9K Radios and Accessories
- 112 FLEX-8000 Signature Series
- 887 Maestro
- 50 FlexControl
- 843 Genius Products
- 434 Power Genius XL Amplifier
- 297 Tuner Genius XL
- 112 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 687 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 916 Third-Party Software
