DC Power Cord Length
Mark Griffin
Does anyone know the length of the DC Power Cord with Anderson Power Pole connectors for Flex 6000 Series? Mark Griffin, KB3Z
1,8m ...figure that in feet ;-)0
I am not sure, I'd guess 10'. I just took a look, but didn't measure it. Of course if Tim sees this he'd know for sure. If that isn't long enough for your environment you can certainly buy it by the foot a a gazillon places.0
Got it in feet: 6 ft was mine, bought a longer one on eBay...0
Just remember if you go much longer then the factory you want to go with bigger gauge wire to cut down on voltage/current loss from resistance in the longer wire.
You can google the wire size loss's and see charts for the length of wire size voltage and current draw or there is a cool Android APP called "ElectroDroid" that has all kinds of very useful info and a lot of calculators for all kinds of Electronic design and info if you have a android device.
73's
Bret
WX7Y
That will be 6ft then :-)
Wow, Electrodroid, thanks! When I made my order, as the 6000 was still a year out in preproduction, I ordered a 1500 and Astron PS large enough to handle the 6000. So when the 6000 arrived I had to cut off those gold (or brass) connectors, tin the resulting leads and I had to work to get their diameter down such that they would even fit in the Astron 25.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
