Having trouble turning TNF off
Len
When I left click on the TNF to turn it off I doesn't turn off I have to keep hitting on it and it eventualy turns off This is on the 6500
any help
Len
any help
Len
I also have 6500 and 1.4 SDR - I just hover my mouse over the TNF and select delete - no problems ever.. running windows 8.1 with all the latest updates etc.0
I've had problems but it's not the software, it's the human. The trick is you can't just hover over what you perceive to be the notch filter, you must have the icon change to the N-E-S-W black arrows. That is the indication the filter context menu (showing delete) will be active on a right click (or left if you have the mouse set other-handed. Very early on I didn't realize that was the icon indication you needed to enable the tnf context menu. That said, the narrower the menu the harder it is to position the mouse to activate the context menu. If you hover over the filter left button down and slide the mouse up (wider) or down (narrower) you can notch out only that signal necessary.0
I'am glad your not having any problems
Thanks Corey I appreciate the info seems thats what I do but it takes while to delete the TNF
All the best
Len
Is it possible you have multiple TNFs stacked one on top of another and you are deleting multiple TNFs?0
I don't think so but it is possible boy TNF really Helps
Thanks TIm
Len
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
