Having trouble turning TNF off
Len
Len Member
edited December 2018 in FLEX-6000 Signature Series
When I left click on the TNF to turn it off I doesn't turn off I have to keep hitting on it and it eventualy turns off   This is on the 6500
any help
Len
  • kg5eiu
    kg5eiu Member ✭✭
    I also have 6500 and 1.4 SDR - I just hover my mouse over the TNF and select delete - no problems ever.. running windows 8.1 with all the latest updates etc.
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited March 2017
    I've had problems but it's not the software, it's the human. The trick is you can't just hover over what you perceive to be the notch filter, you must have the icon change to the N-E-S-W black arrows. That is the indication the filter context menu (showing delete) will be active on a right click (or left if you have the mouse set other-handed. Very early on I didn't realize that was the icon indication you needed to enable the tnf context menu. That said, the narrower the menu the harder it is to position the mouse to activate the context menu. If you hover over the filter left button down and slide the mouse up (wider) or down (narrower) you can notch out only that signal necessary.
  • Len
    Len Member
    edited July 2015
    I'am glad your not having any problems
  • Len
    Len Member
    edited July 2015
    Thanks Corey   I appreciate the info     seems thats what I do but it takes while to delete the TNF
    All the best
    Len
    edited December 2016
    Is it possible you have multiple TNFs stacked one on top of another and you are deleting multiple TNFs?
  • Len
    Len Member
    edited July 2015
    I don't think so but it is possible    boy TNF really Helps
    Thanks TIm
    Len
